the 300 doesn't come with front fans, you have to add them. Also there is 7 slots in the back for cards, so im sure the case will be able to fit 2 video cards.
#1: The A300 does not come with any LED fans in the front. The only 2 fans it comes with is the 140mm on the top, and a 120mm on the rear exhaust. They are black and non-LED. You will have to add 2 fans up front for intakes on your own, and same for the side panel.
#2: Yes it can fit 2 video cards, up to 10.5" in length. Just make sure you do not place your HDDs right behind the video cards.
Good luck. I just finished building one of these cases for a family member.
