MirageMobile
- Jan 22, 2007
Web, Gaming, CAD
~1000-1500
3) Where do you live?
Missouri
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything but case, keyboard, mouse
Just purchase a HAF 922 for $90 shipped, have mouse and keyboard
6) Will you be overclocking?
As I learn about it
20-24
When I get all the specs figured out
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
No RAID or dual GPU support at the moment
10) Do you already have a legit and reusable/transferable OS key/license?
Yes, Win7 64bit
**REVISION**
Here is my current list:
CPU
i5 750 from Microcenter $160 http://www.microcenter.com/single_product_results.phtml?product_id=0302727
RAM+MOBO Combo
4GB G.Skill CL7 + UD3R http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.264219
HDD
Samsung Spinpoint F3 http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
PSU
Corsair 650 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
GPU
Most likely HD 5770
Heatsink
unsure
Web, Gaming, CAD
~1000-1500
Missouri
As I learn about it
20-24
Yes, Win7 64bit
**REVISION**
CPU
RAM+MOBO Combo
HDD
PSU
GPU
Most likely HD 5770
Heatsink
unsure
