First time messing with an Asus motherboard and an AMD proc. Anyway straight to the point. I dont understand the Hyper Transport settings, i know theres something you multiply it with, and that number should normally not exceed 1000mhz in order to leave some head room for mistake, thought some can go up to 1200. I am assuming i should use the HTT but am not sure so im asking.
Next, the frequency of my memory as listed by CPUZ is running much too slow (166mhz when its rated for 250). I read the overclocking guide and it says to use the FSB/DRAM ratio, but there is no such thing that i can locate in the bios. The motherboard im using is the ASUS A8N SLI Rev 1.06 so if its not listed simply as the FSB/DRAM ratio what is it. Basically i just want to find the option to raise it. I have no problem with any of the other memory setting or timings, just these two things. Its a far cry from a locked intel and Abit motherboard. Any help is appriciated.
