Feser One
I have been running the feaser1 with a DD Acrilic top for over a year now with no issues whatsoever. When I did my yearly flush/rebuild the loop was clean and free of any gunk. I would say if you are going to use a pre-mix this is the stuff to use.
Just use distilled water and some PT Nuke. The feser one will stain the acrylic. The dye will eventually separate from the fluid and either gunk up your waterblock or settle in your tubes. MrGoat may have had a good experience, but the experience that I've described seems to be what happens to most people.
If you're stuck on Feser one, go with the clear version and get colored tubing.
"QFT"!!!!!!!!!!!!!!
Replaced all of the FluidXP+ Nano fluid I had in my loops with Feser One clear (blue UV) fluid, it looks fantastic. I'm running all Feser Rads (dual X-Changer 360's in white) with Feser tubing, EK Bay Res and Danger Den res (all acrylic).
Fluid XP was staining everything, now it's nice and clear.
