Feser One $9.99 @ FrozenCPU.Com
davidm71
I don't know about you but I've procrastinated changing my fluids long enough! Looking around I found that FrozenCPU has the Feser One Black 1000ml bottle for $9.99! Must be a price mistake because everywhere else I have looked had it for $19.99...
Link
To bad I did not buy this deal as I need other stuff from Performance-PCS and didn't want to pay shipping twice as FrozenCPU will charge you $9.99 in S&H! But if you need a few other things from them its worth it. I just found that their prices for other stuff was like 1-2 dollars more than performance-pcs..
I bet that black dye would look wonderfully when it falls out of suspension and clogs up everything in your WC loop!
Ice cold deal unless you want to ruin your water cooling loop. Dyes and dyed fluid break down over time and leave a residue that will gunk up your loop. Use plain distilled and a silver kill coil or PT Nuke (or similar additive) and you will never have a problem. I change my loop about once a year and the water is as clear coming out as it was going in and none of my components have ever needed more than a moderate rinse.
I am with Bad, I use $0.88 / Gallon Distilled water and a $4 kill coil and it works better. Once that l dye separates from the fluid you are screwed.
Boy you guys are getting me paranoid! You have a point but what are the odds?
I wouldn't put that crap in my loop if you paid me $10.00
+1 for distilled water and silver kill coil
I have used the same coolant brand and after 2 months it left a disgusting red gunk in on all my blocks that was a PITA to get out. Never went dyed again, straight distilled for me.
I have the Red Feser in two of my machines and have had no problems so far. Both are prob due for a change but I'm too lazy. I have simple CPU loops with clear acrylic blocks/rezzies and everything is still clean @ last check with no probs with temps. (been about a year on each) I am guessing the reason for it..I don't run straight Feser. Mine is about a 25/75 mix with distilled and anti microb. I just wanted/needed some color and don't c the need for that much Feser. Thanks to the OP for posting this..or I prob would not even give my loops a 2nd thought. (Not that I am buying the black Feser, lol) Got two Lans coming up a month or so and I'll give em both a good cleaning and put in fresh coolant using the same. So far been working fine, so I'll go the same route again.
The odds are 100%. Dyes in your loop will result in particulate buildup in your pump and blocks. Colored tubing is the way to go if you want that look (even then, the tubing's dye will gradually effect the loop as time goes on).
My system was running with Primochill UV reactive solution and dye bomb (redundant I know) for over two years without water change. I was too busy the last two years traveling and working to change the water. I did not notice any reduction in cooling performance and no blockage that many here are professing. However, I just did a vinegar clean etc... and put in new primochill and dye bomb. I did noticed some buildup but nothing significant that would warrant an apocalyptic-like freaking out.
However, to each his own, do what you think is best aesthetically and functionally for you. Life is too short to freak out about somethings.
