Just picked up a new scanner and in the process of installing the software I started reading the manual. (New concept) I found the following line ... "Use of a shielded cable with the ferrite cores(s) provided with the scanner is necessary to comply with the technical requirements of the EMC Directive"
The question(s) I have are .. Are the ferrite cores there to prevent problems with the scanner or with other devices near the scanner and will my scans be affected by using a standard USB 2.0 cable without ferrite cores?
Thxs in advance for the info.
d
d
