http://www.techpowerup.com/116114/GeForce_GTX_400_Series_Performance_Expectations_Hit_the_Web.html
IF this is true....i'm disappointed
The performance specs don't make sense. It says a 448 or 480 core part will only perform at 5850 speeds (gtx 285 territory), while the 512 core part will be twice as fast a gtx 285? Why would such a small decrease in shader units decrease performance so drastically?
Sources tell DonanimHaber that the GeForce GTX 470 performs somewhere between the ATI Radeon HD 5850 and Radeon HD 5870. This part is said to have a power draw of 300W.
Considering that the article is referencing a clearly fake site for the price, I find its facts dubious.
The site it references at the $699 price, is SabrePC.
Now on that site, it lists an XFX GTX 480 with 2gb memory. The problem being, that there will be no 2gb memory models. The 480 has a 384bit memory bus, built on 6 64bit memory controllers.
128mbx6= 768mb (128mb is most used memory size, but this seems too small for flagship)
256mbx6=1.5gb (probable memory standard for the gtx 480)
384mbx6=2304mb (weird sized chip, but closest to 2gb, will never be put in 480)
2gb/6=341mb (no such thing as a 341mb memory chip)
TLDR, the price is bullshit because the listing can't even get the memory size right. With that fact of this article wrong, it throws into doubt all other conclusions.
What is fake about the site. SabrePC is in San Jose .. near to Nvidia HQConsidering that the article is referencing a clearly fake site for the price, I find its facts dubious.
actually we do know that the top card will be 384bit so the 470 will likely be 320bit since theres little chance they will drop all the way to 256bit. so there is no way that the 480 or the 470 will have 2gb.What is fake about the site. SabrePC is in San Jose .. near to Nvidia HQ
- the price may be fake - or not - according to Nvidia
We also don't know for sure about GTX 470 specs.
We don't know that there will not be 2GB models
we just don't know
If this is true NVIDIA failed, they had all this time to make a better card and yet it fails to perform faster. Fail.
we just don't know
Aren't there 512MB GDDR5 modules? Maybe a 3GB version - or is that precluded by the architecture? i just don't remember the white paperI agree, we don't know for sure the 470 specs.
We do know for an absolute fact there will not be a 2gb GTX 480. The architecture clearly precludes it. The memory size is dictated by how many memory controllers there are, and what size memory module they use. We know for a fact the 384bit bus has 6 memory controllers. We also know for a fact they will use 128mb or 256mb memory modules. Which means, we know for a fact that you cannot get a 2gb card from that architecture. You can get a 768mb, a 1.5gb, and a 2304mb card, though I don't think they make 384mb modules anyways, so just take that 2304mb card off the list.
Since 768mb isn't enough for a flagship card, they will have 1.5gb.
