GoldenTiger
- Dec 2, 2004
http://www.bjorn3d.com/forum/showpost.php?p=215717&postcount=8
The editor of the Bjorn3D review site has this to say about Fermi, posted late last night:
Methious said:--------------------------------------------------------------------------------
Design Article releases tomorrow 7PM CST with complete Whitepaper info.
New Features, new cache, new Memory setup, and yes it's about 100% performance increase over GTX-2xx so figure single GTX-285 vs 5870 then double the GTX-285 performance.
Then it handles triangles different, triangles on any given frame can number in the hundreds of thousands so that's very important.
It will fold a lot better.
Increased efficiency in several areas.
It's a revolutionary new design oriented toward tessellation (those pesky triangles) and geometric programming. Problem being every wire frame is made up of triangles, tessellation takes those triangle and breaks them down into many smaller triangles. This core is uniquely designed to handle that so geometric and shader heavy games you will see more than the 100% raw power increase.
520USD might handle it. At 2x GTX-285 performance that puts it above GTX-295 performance and it's DX11 ready and designed for that specifically. Current ATI offerings are really good but basically a double the hardware on the same core design to provide more raw power. GF100 is a core design to take advantage of what the industry needs today and for some time in the future.
Read the article tomorro cause that's about all I can say tonight.
