Felt's PC Build
felt
Web browsing, Gaming, Video editing.
$1,000 give or take a few hundred $$
California, Los Angeles (Microcenter/Frys are local)
Case/PSU/CPU/Memory/HSF/Monitor/GPU
Keyboard/Mouse/Mousepad
6) Will you be overclocking?
Yes, mild overclock.
Don't know yet. Please recommend for 1080P gaming
This week or next week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Be able to utilize my Samsung EVO 850 512GB SSD
Using Windows 7 64b
This is what I currently have picked from Microcenter
Intel Core i5-4690K 3.5GHz LGA 1150 ~$189
MSI Z97 PC Mate Socket LGA 1150 ATX ~$59.99 (Bundled price w/ CPU)
EVGA 600B 600 Watt ATX Power Supply ~$64.99
Corsair Carbide Series 300R Mid-Tower ATX ~$69.99
Cooler Master Hyper 212 EVO Universal CPU Cooler ~$34.99
LG GH24NSC0B 24x Internal DVD Rewritable SATA Drive ~$14.99
EVGA 16GB DDR3-2400 PC3-19200) CL 11 ~$99.99
Total $577 w/ tax.
I plan to use the onboard GPU until I decide on what video card to buy to game at 1080P. I'd like to play current and future games .
I already purchased my SSD which is an Samsung 850 EVO 500GB 2.5" SATA III.
I would like to overclock the CPU to around 4Ghz, fully utilize my SSD and have good onboard Audio and USB 3.0
This is my 2nd computer, my other computer has 2TB of HDD storage and is my utorrent/plex server.
If I left anything out, please let me know. I'd also like to see if I can save a few dollars , so if you have any suggestions, please let me know.
Thanks!
At $65, that eVGA PSU isn't worth getting since there are better options for the money online. Like this for example:
$66 - XFX TS Series 550W PSU
Personally, I don't like the idea of using RAM rated higher than 1.65V due to potential CPU longevity issues. BUt that is a decent price for the RAM.
thank you for that suggestion.
why would the ram at 1.65v cause issues with the cpu? i did see that majority of ddr3 is rated at 1.5, maybe i can drop the ddr3 volts down to those specs instead? I don't plan on heavy overclocking so that might be an option?
Last I checked, Intel's recommended max voltage for RAM was 1.5V. You could indeed lower the voltage but that also means lowering the frequency of the RAM as well. Though that itself won't matter since current Intel platforms do not take much advantage of higher speed RAM. In other words, for most real-world apps and games, you wouldn't notice a justifiable performance difference between DDR3 1600 and DDR3 3000.
