How does felt do with dampening sound/vibrations? I'm building a PC case out of some kind of wood and felt seems like the perfect way to mount the HDDs and drives (I was going to use slide in rails with felt on the surfaces of the wood that would be touching the drives). I also thought about lining the 6 inner sides of the case itself to deflect/trap some of the noise. Was probably going to cut everything out and put it all together and then glue the felt down and cut it with a utility knife so it's perfect.
thanks for any advice and tips
