Fellow Oblivion SLI users please help!
Oblivion will NOT read my SLI, I need to know if this is a bug with windows 64 bit.
(your drive) My Documents\My Games\Oblivion\RendererInfo.txt
please post the contents of this file if your running SLI !
heres mine:
Renderer Device Information:
NVIDIA GeForce 7800 GTX
nv4_disp.dll
RenderPath : BSSM_SV_2_A
PSversion : 300
VSversion : 300
VStarget : vs_2_0
PStarget : ps_2_a
PS2xtarget : ps_2_a
maxPS20inst : 512
3.0 Shaders : yes
Image space effects : yes
Nonpowerof2textures : yes
FP16ARGB blending : yes
FP16ARGB filtering : yes
High dynamic range : yes
Bloom lighting : no
Refraction : yes
2.0 hair : yes
SLI mode : no
Water shader : yes
Water reflections : yes
Water displacement : yes
Water high res : yes
Multisample Type : 0
Shader Package : 13
I am running 2 cards :mad: :mad: :mad:
Using 84.21 forcewave (the newest available for windowsx64)
Thank you to anyone who takes a minute to do this for me, if I have to downgrade to 32 bit windows I will.
-mike
i can verify its not working because the "display load balancing" bar does not load on the lefthand side of the screen.
-mike
Try forcing "global settings" (in the nvidia control panel) to multi-GPU, which should show Oblivion the second card. That should work until the next 64bit drivers are available that are coded for Oblivion.
i was hopeful with this great suggestion. so i forced global, and MULTI in the control panel, fully removed (including the my documents folder) the game, then reinstalled, opened it, then went to look at rendering info:
2.0 hair : yes
SLI mode : no
Water shader : yes
:( i really have no clue on this one. other guys are saying it works but they all run 32 bit windows.
my only lead is this: in that same file at the top it says:
nv4_disp.dll
perhaps i need an updated version of this for the game to correctly see my computers config. i recognize it as part of the forcewave driver package.
sigh.
2.0 hair : yes
SLI mode : no
Water shader : yes
nv4_disp.dll
sigh.
Too bad that didn't work, I guess you're stuck until nvidia releases the x64 Oblivion compatible driver. SLI does work in 32bit, so it must be the x64 driver that's causing the problem.
