I have decided to do some serious consolidation and upgrading at the same time. Right now I have multiple E8400-based systems that are getting a bit long in the tooth. What I am looking to do is both upgrade to a newer system, at a minimum a Lynnfield core, or possibly a Sandy Bridge core, and consolidate the multiple systems into a series of virtual machines using VirtualBox. At the same time, I want to build a centralized storage server that will likely be 12TB to start
Here is where I need the most feedback. Consolidating the multiple systems into multiple VMs is cake and straightforward. I will have anywhere from 4 to 10 at any one time, but they will not be run 24/7, just when needed for testing and development purposes. However, the system I build for storage, using ZFS, will be run 24/7. Does it make sense to make the ZFS storage server a VM running 24/7 within my primary workstation, or should it be a dedicated box - essentially a NAS on my LAN?. The new primary workstation that I am considering will have a minimum of 16GB of RAM and will either be based upon an X3440 Xeon CPU or a newer i7-2600(K) CPU so it should have plenty of horsepower for my day-to-day work as well as powering a storage VM if needed. I also have plenty of storage space with the case I am intending to use - an early gen CoolerMaster Stacker.
What I am unclear about are the potential downfalls of running a storage server as a VM versus as a dedicated box? Are there serious limitations with this kind of setup?
