just wanted to get a little feed back on my new site @ www.korizz.com
thanks
thanks
Here's what I would change...
- Move the Username and Password to the top
- Center the Youtube Video
- Put Administrator at the bottom header, as it's pretty much useless for the majority of the users (at least I think so for your website?)
- Center the House of Korriz and I would add it the pretty much empty banner above it. Just put it in the middle.
- Also not really necessary but the artistic side in me would have that the House of Korriz in a cool type of text or picture.
- Add a favicon, which once again isn't really necessary.
- Increase the quality of the jpeg on the background, you can see it getting all jpeg-ingly disgusting
Otherwise looks good man.
Switching it to a .PNG also helps with the crappy jpeg-ness. If you do the things listed above, I think it'd look excellent.
Yes without a doubt, however .png files are large and not ideal for background images. They take longer to load.
and that tab effect that makes the text jump to the right when hovered- Change hyperlinks to be without underlines (optionally underline when hovered)
I mentioned that one, tooand that tab effect that makes the text jump to the right when hovered
- Change top-center links to not left-pad the text when hovering
