Fedora 16 Live-cd Grub2?
dizzy4
Hey all, I have been trying to figure out how to get a more fully functional and configureable boot-loader onto a live-cd or live-usb. I am trying to create my own custom spin (which works VERY well), but I am stuck trying to get some better boot options than what it puts on there by default. Specifically I am looking for multiboot. I need the live-usb to boot the Xen hypervisor first then the persistent live-usb image as the dom0. This is very easy and configured by default if you use anaconda to install the live-image to a disk. Grub2 just works and has all the proper Xen boot options as well. It would seem easy enough to use this in stead of the default and I know that the Xen live-cd (using debian) has grub2.
Any help is much appreciated! :)
It's a great program but it doesn't solve my dilema of having a custom boot menu. I want the end user to have one boot option that is customized. The way it is done with Grub2 works well. Unfortunately, UNetbootin does not use a grub2 boot loader. I need support for multiboot because I want Xen to boot first then the linux distro as a dom0. This is already configured in my ISO and will work right after Anaconda installs the live-image to the disk with a grub2 boot loader. I have no problems creating a USB from an ISO, I just need to figure out how to edit my fedora spin to use a different boot loader.
Will not do, nor will the UNetbootin.
