Fear and Dual Monitors
ComputerBox34
I just got a dual monitor set-up going and everything is working great. The only thing that I haven't been able to fix is that FEAR keeps on being displayed on my secondary screen. How do I move it to my primary?
You should be able to change it on the fear configuration utility. There you can choose the resolution and the display.
You should have a shortcut to it in your start menu, if not just lunch config.exe from the fear folder.
