FEAR 2 5$
Whoa, I think this is a must-buy then...
Wow, GFWL's downloading this at about 1/10th the speed I can get off Steam. This is going to take an entire day...
Pretty shitty considering it has the MS name attached to it...
Yup. Give yourself some time for extraction and installation, too. Last thing I'm buying from that store.
the install was the most annoying. I downloaded it rather quickly (a little over 3 hours for 14GB), but installing from the same drive (a vraptor) that the download was on took far longer than necessary. Either way, $5 for a game + DLC that would be $30 through steam, I can handle the inconvenience of a single install.
The difficulty level on Normal is quite trivial. If you're looking for any sort of challenge, I suggest Hard mode.
It's been years since I've played fear 1. Maybe I should replay before tackling fear 2. Strangely, fear is a game I've always enjoyed. Yet, I've never bought it unless it was in the bargain bin.
Anyway, thanks for linkage. A no-brainer buy.
I'm sure that the game is a great value for $5 and all, but GWFL is a piece of shit.
As stated before, super slow download speeds. I managed to get about 3gb of the game over the last 5+ hours. And then GFWL randomly hardlocked and lost the download. Yes, back to 0%
Truly awful piece of shit software.
Well thankfully the GFWL store is going away soon. With any luck MS will have a much better set up with that stuff once the GFW Marketplace launches.
Weird, my download was flying at about 5.5MB/sec. Now I need to figure how to get it to work right with eyefinity. Not working so far.
I'm using Surround, but here's what I did:
Get out of Surround mode and boot the game up normally.
Set your secondary graphics settings and make sure Widescreen is set to "off".
Exit game.
Open the Settings.cfg file in your WB Games folder under My Documents and manually enter your desired resolution.
Boot up game.
Go to settings and switch the aspect ratio until you're able to choose higher resolutions.
The graphics are nothing special so performance is smooth. Couldn't get SSAA working though. And I turned off that shitty grain filter so at least everything looks clean.
The download max'd my DSL connection at 3 Mb/s.
Just as you described it dropped the download ... twice. You don't have to start from square 1 though, just click pause, close down the client and reopen it. In fact if your download gets sluggish do that also.
fffffffuuuuuuuuu GFWL installer. It just raped my SSD. Even though I have it download to one of my traditional HD's it extracts it to C: before it installs. Fuckers, now I have to manually extract it.
Thanks. Looks like Live is probably getting hammered this evening with the Xbox dashboard update going out so GFWL is slow as heck at the moment.
Yeah, my download was slow all day, then suddenly last night it shot up in speed and quickly finished downloading at like 3am, when it was looking to not be done 'til maybe noon.
I immediately thought it must have just been getting hammered for some reason. Unless a lot of people were just buying FEAR 2, doubt it though.
My download is actually going pretty fast. I initially had a problem signing into GFWL so if you guys use GFWL only occasionally and have a problem you might need to agree to their updated terms.
I went to xbox.com and signed in with my Live account and had to accept their updated EULA before it would let me sign into GFWL. Loading the pages and GFWL was slow but the download is fast so perhaps that content is hosted elsewhere.
Where are you seeing the Reborn DLC? I bought FEAR 2 a couple days ago and don't see any sign of a DLC.
is anyone else having problems getting it to run? it doesn't like my sound blaster apparently. there is all kinds of threads about sound issues but they are pretty old.
and the damn thing is that the audio worked fine on the demo
