BrainDanceR
- Aug 18, 2004
Hi Peeps.
Sorry, if this is a little noobish, but I would like some help before I trash my box
First, a little history about my aging rig:
My original system came with a 20GB HD (back in 2000!), with Windows 98.
About 2 years later, I bought a new 120 GB drive, partitioned it into 2 (60GB each).
I then installed Windows 2000 onto one of the partitions.
Then, about 2 years later, I installed windows XP on the other partition.
So Basically, my system is now:
MASTER Disk 1(20 GB) - C: (boot disk, windows 98) FAT 32
SLAVE Disk 2(120 GB - 1st 60GB Partition) D: (Windows 2000) NTFS
SLAVE Disk 2(120GB - 2nd 60GB Partition) E: (Windows XP). NTFS
I now want to get rid of that old C: drive, as its an IBM deathstar and starting to click.I feel Wont be long till it dies.
Now I only want to use the 2nd Disk, and reinstall Windows XP on the first partition, and keep my data on the second partition.
So how do I do this without losing my data from the second partition?
I am guessing I need to just set the 1st partiton to "Active" with FDISK, then format C: /s ...
Will this work,does it create all the boot.ini stuff I need? Also can I format NTFS in DOS?
Argh....probably being really thick...
