If you don't have a specific need for FC SSD's (or don't want to RAID/JBOD them), you might want to fleabay them (a 5 pack generally goes for up to $500) and purchase some SATA/NVME drives you can more easily integrate. They are most likely EMC pulls and they are good drives. Which HBA's did you get? Do you have the requisite cables/connectors/T-Adapters etc?
Which 2640 version do you have, the one with HSSDC or SC optical connectors? Basically, the reason I suggested selling the FC drives unless you specifically need/have a FC infrastructure is because if you don't have everything it isn't cheap. You are going to need 5 T cards (or a backplane) with the proper adapter cables (DB9/HSSDC/PTP) and possibly a GBIC adapter to go from copper to fiber. It is not going to be cheap, probably 300-500 (or more) by the time you are done if you need everything. You can find some more info on interfacing bare FC drives to your PC here and here. You can get 12Gb/s 400GB SAS SSD's on fleabay for about $200 or so, you might be better off selling the FC drives and using the money to buy SAS drives in its place. Easier to configure and a lot less to go wrong.i would like to get them working if possible i hate sata drives (my curent system is a large raid of sas drives) and nvme drives dont like to work well with my mobo. i would raid them if i can. curently all i have ia a qlogic qle 2640 hba and these drives. im looking for the cheapest way to get them running.
you have 5 FC drives and 2 HBAs? You can't connect those drives to those HBAs, as does not work that way. Those cards are for connecting from server to array not server directly to drives. Anyway you dice it, it'll be hokey and hacky as all hell. The best way is to find a case that supports FC drives, and you put your drives in it, then out the FC ports on the back of the case to the FC cards installed into your server. If you want cheap? Get some sata to FC drive adapters and throw the drives on your current mother board. Other alternative is to buy a SAS card that supports FC or get SAS to FC adapters.
one more thing, the 2460s are OLD. They are no longer writing supported drivers for the latest version of Linux or windows. Well.. you can download the drivers, but they haven't been updated in years, so they may or may not work, and if they work performance or reliability would be an issue.
one more note.. I reached out to my contacts over at EMC.. the drives you have? yea.. they have custom firmware on them from EMC specifically for VMAX and most likely will not function properly with any other array other then a VMAX or VNX. You may be able to reflash them, but highly unlikely as that part number is enterprise customer use only.
