Fax & Wireless Network
cu2cool
Is it possible to use a fax machine/printer through a pc connected wirelessly to a router? I have a comcast modem (high speed internet/digital voice) and wireless router installed in one room, and don't want to have to move it to another room that is currently using wireless internet. I want to keep my current config because I like having a direct line connection to my router to get the max speeds. If there is no solution to wirelessly using my fax though, how would a wifi-N connection compare to a 100Mbs connection? I think I can get up to about 300Mbs connection speed to the router through my walls, but does it really have the same d/l and u/l speed capacities as a hard connection? Please help...:confused:
