faulty motherboard?
barefootbilly
or power supply?
simple problem i guess. Woke up and the computer was off, but the green light was on when i opened the case.
Plugged in only the essentials, but left the 4-pin power supply connector to the motherboard unplugged. It appeared to boot up, fans were spinning, all was good.
Put a video card in, plugged the 4-pin in, green light comes on but no power up. :(
Conclusion after a couple tries: powers on if the 4pin connector isn't plugged in.
mobo or psu?
try a different psu, and if the problem persists, i'd say move to the mobo. Before anything though, recheck all your connections and clear the cmos.
did that, still won't power on if the 4pin atx connector is plugged in. It will power on without it though :(
I'd definetly try another power supply then. If you don't have an extra, borrow one from a friend, lol.
