Faulty capacitors claims another
cappyboats
Well, I was doing some spring cleaning of my case and was going to add some more case mods when I noticed I had the "Famed" leaking capacitors. The board in question was a Soltek SL-86SPE-L. I was having erroneous errors but thought I had a bug I couldn't find. Now I am thinking that these caps may have had a hand in it. I sent Soltek a nasty email because I have used several of their products and still have 2 of 6 computers running Soltek boards. Since they have pulled out of America, I will no longer buy their boards. They were my first choice after ASUS several years back when ASUS was just getting too expensive.
Are the caps near the DIMM slots swollen too? The look like they're reflecting the light a little differently.
do you have the skills to change them??
I have repaired the caps on several boards and they work fine afterwards..
good luck
ojibewa
Yes there are several swollen and not just by the DIMM's
good luck
ojibewa
I do, but the hassle didn't outweigh the Gigabyte GA-8IPE1000Pro-G I picked up from Newegg's refurb's for $47.00. I also checked "that" auction site to see if it was worth fixing and then selling but it really wasn't . I may fix it anyway as a spare since they're starting to get away from making the skt 478 boards.
good luck
ojibewa
Can you recommend a good place to pick up the caps at?
MD_Willington said:
http://forums.pcper.com/showthread.php?p=3470121#post3470121
go here, email lydia, soltek will send you new caps or if the board is less than 13 months old they will fix it..
Badcaps.net
Thanks for the link MD, I got the caps for two of my motherboards that are Soltek. I had mentioned in my email to Lydia that I was using a standby machine on the SL-FRN2-RL and she sent me new caps for that board as well. I finished changing out the 14 caps on the Intel board and will test it tomorrow. The Gigabyte board I got off of Newegg refurbs absolutely refuses to work with my MX duo but will work with regular mouse and keyboard. Thanks again for the linkage to Lydia.
