Using the right media, you can definately hear the difference between the x-fi and some cheaper sound cards. If your media is low quality lossy format MP3s, the difference may never be appreciated.
The difference between the X-fi extreme gamer / music / fatal!ty and the Azuntech Prelude is much more subtle, but when you have a high quality set of headphones, or speakers (not suggesting that the logitech z-5500 is bad or anything) the difference between the x-fi and the prelude becomes much more obvious. Remember again, you must be using a high quality media to discern the difference.
So what does all this mean. It means most any good sound card will sound good on your z-5500s. If you game and want to take advantage of the discrete gaming EAX 5 protocols, then yes the X-fi is a great option. Also if you are looking for even better sound, still want a single sound card solution, and have the audio gear to make use of it, a card like the Azuntech Prelude is a great choice.
Is it worth $200, that is totally up to your own definition of worth. Remember we all play in different states of disposible income, and wanted desire. You will have to decide if its worth it for you.
