Fatal Error from ati3duag.dll
Modulus-X
I have recently been getting random restarts while using my computer. It can happen when I use any of my programs. It totally crashes and the computer immediately restarts. No BSD no nothing. I would call ATI but they charge $1.25 USD per minute (!!!). So I am here begging for help. My Computer specs are as follows:
AMD Athlon Xp 3000+ Barton
Asus A7N8X Deluxe
ATI Brand Radeon 9800 Pro
Crucial Brand (2)512 Sticks of DDR 3200 RAM
Here is what I have done so far:
Sent back a memory stick I thought was faulty, turns out it isn't.
Reinstalled my drivers 3+ times using driver cleaner.
Analyzed dump files.
Here is my most recent crash. It must have happend less than a half hour ago (I apologize for the formatting problems in advance, just copied it out of the bug checker.):
Microsoft (R) Windows Debugger Version 6.3.0005.1
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini021104-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: C:\WINDOWS\Symbols
Executable search path is: E:\I386
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
Windows XP Kernel Version 2600 UP Free x86 compatible
Product: WinNt
Kernel base = 0x804d0000 PsLoadedModuleList = 0x8053e0a8
Debug session time: Wed Feb 11 15:10:14 2004
System Uptime: 0 days 2:32:00.906
Loading Kernel Symbols
Loading unloaded module list
Loading User Symbols
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c0000005, 0, aa984abc, 0}
Unable to load image ati3duag.dll, Win32 error 2
*** WARNING: Unable to verify timestamp for ati3duag.dll
*** ERROR: Module load completed but symbols could not be loaded for ati3duag.dll
Unable to load image win32k.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for win32k.sys
Unable to load image watchdog.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for watchdog.sys
Unable to load image dxg.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for dxg.sys
Probably caused by : ati3duag.dll ( ati3duag+268b7 )
Followup: MachineOwner
kd> !analyze -v
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
An exception code of 0x80000002 (STATUS_DATATYPE_MISALIGNMENT) indicates
that an unaligned data reference was encountered. The trap frame will
supply additional information.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 00000000, The address that the exception occurred at
Arg3: aa984abc, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
FAULTING_IP:
+0
00000000 ?? ???
TRAP_FRAME: aa984abc -- (.trap ffffffffaa984abc)
ErrCode = 00000000
eax=00000018 ebx=e3bc7018 ecx=00000000 edx=00000000 esi=e2c02230 edi=00000000
eip=00000000 esp=aa984b30 ebp=e2a68010 iopl=0 nv up ei ng nz ac po nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010296
00000000 ?? ???
Resetting default scope
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0x8E
LAST_CONTROL_TRANSFER: from 00000100 to 00000000
STACK_TEXT:
aa984b2c 00000100 00000000 8ca743ff e2c02230 0x0
FOLLOWUP_IP:
ati3duag+268b7
bfa218b7 ?? ???
FOLLOWUP_NAME: MachineOwner
SYMBOL_NAME: ati3duag+268b7
MODULE_NAME: ati3duag
IMAGE_NAME: ati3duag.dll
DEBUG_FLR_IMAGE_TIMESTAMP: 3fd9fc4c
STACK_COMMAND: .trap ffffffffaa984abc ; kb
BUCKET_ID: 0x8E_ati3duag+268b7
Now the question is, what do I do to fix this???
If you need more info let me know I am willing to go get it.
err , does ATi have a tech support e-mail you can reach 'em at?
feel like a good ol' Reformat?
vid. card not pushed in all the way?
vid. card fan dead = overheating?
are you OCing?
