- Feb 22, 2001
Question for you guys. Is it ok to put a fat32 filesystem for windows XP? Advantages/Disadvantages.
Your wish has come trueOriginally posted by BillLeeLee
It's fine to run Windows XP on a FAT32 file system, I do on one of my comps, but I wish I had used NTFS instead.
IIRC you take a little performance hit by using the conversion method, if you have the time to do a fresh install it's the better path.Originally posted by Met-AL
Your wish has come trueOpen up the command prompt in WinXP (Start Menu/Run..type CMD...) and enter this command in: CONVERT C: /FS:NTFS
Change the "C" to the drive you want to convert. This is only a one way ticket. There is no way back without a third party program such as Partition Magic.
FAT32 (File Allocation Table) is an old file system; it is simple and readable to work on a large number of operating systems. But, recently, it is understood that the usage of FAT 32 always been replaced by NTFSthe superior partition format.
NTFS (New Technology File System) is the standard file system of Windows NT, including its later versions Windows 2000, Windows XP, Windows Server 2003, Windows Server 2008, Windows Vista, and Windows 7. NTFS supersedes the FAT file system as the preferred file system for Microsofts Windows operating systems.
Considering the superiority the NTFS gives, people would like to convert FAT32 to NTFS.
I just know that operation is simple to realize, but if revert NTFS back to FAT32, it will be a complex operation.
Luckily I have just heard that there is new released software named NTFS to FAT32 Converter. It can easily convert NTFS to FAT32 without data losing. Mentioned here, help you all deal with this problem in case.
