Answer moved here when I realised it may contain information that our competitors may find useful. Didn't want anybody shouting at me upon dawn in the US
I only ran Cosmology on a G34 4p for a short while before LHC started but I'll give this a go while the experts are sleeping.
There didn't appear to be a great points advantage for planck tasks over the non virtual box single thread work (camb_legacy) but what I liked was that tasks finished much quicker. Some of the legacy tasks took days compared to an average of about 30 minutes per task using the settings below. This is becoming important now that we only have a couple of days or so left.
If you decide to switch any boxes over another important consideration is that when leaving the config of the planck task as default boinc tried to use 32 cores of my 48 core box for one task which had a cpu utilisation of less than 50% for some reason. After some experimentation the optimal number of cores turned out to be 4 for each task and so my app_config file was:
app_config>
<app>
<name>lsplitsims</name>
<max_concurrent>12</max_concurrent>
</app>
<app_version>
<app_name>lsplitsims</app_name>
<plan_class>vbox64_mt</plan_class>
<avg_ncpus>4</avg_ncpus>
</app_version>
< /app_config>
You will, of course, have to make adjustments to account for the number of threads on your box and to allow for the legacy tasks to finish.
YMMV and good luck!
Now I'm wondering... have I been screwing myself over in other projects by not using the VM enabled BOINC option? In the case of the current Pentathlon competition, am I leaving points on the table by not going that route? Inquiring minds want to know! Thanks!
app_config>
<app>
</app>
<app_version>
</app_version>
< /app_config>
YMMV and good luck!
