Fastest while running Teamspeak
SLiLOVER
Which of these CPU's is the fastest when you are playing BF2 and you are on teamspeak at the same tim?A FX-53,a 4000+ San Diego,or a 3800+ X2?
id say the X2 OC its and make sure you set teamspeak to the other CPU and your good to go :cool:
Yes you can. Its called setting the affinity. (Under the task manager ---->processes ---> Rightclick desired process)
If it is something you want to set the affinity of on a regular basis, use a program like Runfirst to automatically set a program to the first core.
If you go the x2 route, I would suggest just running everything you want first and see how it goes. It might not need any affinity to be manually set.
toymachineman19 said:
X2 definatly...but TS really doesn't use that much CPU power... although with BF2 it's understandable.
There will be no difference when running TS... is it by far the lighest program you could possibly run. You have no need of a dual core cpu to 'optimize' your gaming. Check the system reqs, hell I think there are pocket calculators it can run on its so light on a system.
a p3 or even a p2 can run TS fine
I think its time to upgrade to a fx 57 I think my aim is slowing down :rolleyes:
