SSD in an USB3 enclosure.
You might consider the 64GB version of this:
http://www.amazon.com/Corsair-Flash...dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
I have the 32 GB version. It transfers at round 40-70MB/s when plugged into a usb 3.0. Note that on my system those same files moved to a MyBook WD (3TB) at about 120MB/s. It is slower than a real HDD or even a slow SDD.
This 32GB version drive is about 3.75 inches long.
And then:
http://www.amazon.com/s/ref=nb_sb_s...+drive&x=0&y=0&sprefix=128+GB,electronics,174
Hrmm.
Well, what about the Patriot Supersonic Magnum 64GB?
It has a sustained speed of 120MB/s write.
I think the actual rate will depend on the file sizes you're transferring, but I see no reason not to go with that one...the reviews are more or less the same. I would pick the smaller one, as the corsair is the biggest usb stick I've ever had.
No offense man, but that Corsair GT looks like some doggy chew toy
I guess I'd be okay with something around 70MB/s write if it were small.
