Fastest Socket A motherboard
Toad21
What is the fastest socket A motherboard on the planet?
I have a 3200+ that is unlocked!! and ram capable of 500 mhz, but my mobo(A7N8X-E Deluxe) can't go past 224 fsb.
Is there a motherboard that can break 260fsb?
Are you sure your mobo is limiting you? nforce2 boards can unlock any barton chip, and my barton 3200+ only hit a fsb of 208 before crapping out. the 3200+ is the last of all the barton chips, so they aren't the best for overclocking. if you wanna go faster get a mobile chip, they oc better and would cost about as much as a new board. as for better overclocking boards, go dfi or abit, although i doubt you would get much more from that cpu
This processor is basically unlimited. I can put the multiplier at 5 and get 300fsb in theory. Its the motherboard that is limited. Thus my original question ;p
I want to know the highest fsb of any socket A motherboard. Can anyone help me out?
You have approximatly arrived at the average best FSB on an Athlon XP motherboard. Most will crap out around 220, while the rare gem (usually your board, a nf7-s, or bfi infinity) will be able to hit about 240 stable, but all i've seen attempting 250 melted down shortly thereafter.
With that being said, you should note that the Athlon XP platform doesn't get a huge kick in the pants from FSB increases- its all about latency and clock speed. Thus, if I were you, i'd concentrate on running 2-2-2-5 ram timings at a 200-210 fsb (or lower, depending onyour ram).
If you are bent on being able to hit at least a 250 fsb on a consistant basis, you'll need to buy a PIV. Many Athlon 64's boards can hit that FSB, but its usually spotty to find one that will.
Getting better timing ram didnt help my Sisoft sandra 2004 or pc mark benchmarks. What gives!!
I wish I knew this before I bought a 3200 Unlocked. I had a 2800 that would do 2.4 ghz at 183fsb. So I paid 60$ to go from 2.4ghz @ 183fsb to 2.52ghz @ 210fsb.
And here is something wierd, this 3200+ runs very hot! Even when DOWN clocked to 166mhz, 2.0ghz or something, it runs at 43 c idle!!! So:
166fsb 2.0ghz = 43c idle
210fsb 2.52ghz = 44c idle
And this is with the worlds best Zalman Heatsink fan. Weird!!
Its probley not the CPU limiting you, as most CPUs will do 250fsb. With the right multiplyer keeping the MHz in range of its maxium...There are alot of things nessary to get 250FSB stabel. I had 250 stabel on my DFI infinty.
Power supply, no nessarly the watts of the PSU but how strong the rails are. You want a good one, with all rails at or above spec. 5v, 3.3v and 12v. Haveing them above spec, offen higher helps alot... (es 3.45v, 12.25v. 5.4v) but its risky, as it can dammage some hardware, you also need to look at the amps on ech rail, you will need at least 22amp bare minium for a a64, i guss 17amps on the 12v will run, but 22 is best...I prefer the 33amp 12v line of the entermax PSUs.
Memory, you either get high speed and week timings or lower speed and fast timings. Generally its all the same memory, just setup to SPD read what timing it is. If you notice alot of PC4000 is the same memroy chips as some PC3200 or 3500, jsut weeker timings. I guss there comming out wth some low timing fast PC4000 that sounds nice..$$$....not all memory will run at its spec. expecially genric untested stuff.
Motherboard, this is kinda hit or miss, It take some luck to get a motherboard capibel of higher FSB like 250. Since the memory controller is on the motherboard on a AthlonXP system the Main board is very importiant. just about all Nf-7 board will do 220 or so. Its a well built board. The DFI infinty seems to be a great FSB overclocker. Yea the voltage that it feed the CPU is crap, off just about all the board the ship have a top voltage of 1.825 anythign after than is unuseabel even at stock speed. Even thought they offer 2v Vcore in the BIOS the power circut is only good for 1.825v of strong power. With will hinder a higher overall MHz. What is a 250Fsb if you can only give you core 1.8v and run 2.3-2.4Ghz? .....The best board i ever used on that platform was the Abit An7, it was only good for about 230 FSB or so Avarage. But had great power and voltage options. I ran my 2600M @ 12x235 for 2.82 Ghz with 2.2v Vcore. It ran 235 FSB perfectly and with 3.1v to memory and some low timings i think i ran 2.0-3-3-11 i beat out alot of 250FSB guys in bandwith benchmarks...
And do i even need to mention cooling?
All and all i recoument the Abit An7 with a new BIOS. great board overall the best IMO.
I have personally used the following SockeyA M/Bs
Epox 8rda
Epox 8rda+ never
ASUS A7n8x Delux very early one (sucked ass IMO)
Abit NF-7 (cant go wrong with this one) missing Soundstorm thoguht....so ge the NF-7s
DFI infinty Ultra II (good FSB, but overall i hate is too many major problems) I guss if you got an early one made in china not tiwann then there good, mine sucked.
Abit AN7 (#1 IMO)
Abit Nf-7s2 (friends computer i helped him overclock wiith his SLK900) Seemes good, FSB craped out at 219 with 2x256 corsair 3200LL but we got his 2600+M to 2.78Ghz... )
Remember that SiSoft and PCMark are synthetic benchmarks and are not true indicators of your pc's performance. The effect of tighter ram timings typically show up in real world tasks, such as games, multitasking, media editing, etc.
wORD!
Sisoft Sandra is a great utility but I wouldn't bet the farm on some of the benchmarks. They are synthetic benchmarks BTW. A "Seat of the pants" feel for real applications is worth more than synthetic benchies any day IMHO.
