NKDietrich
- Jul 25, 2004
Its been forever since I even looked at AGP cards, let alone PCI. What is/was the fastest PCI video card made? I lost track of PCI around the time of Voodoo 3.
Go with a 6200 for performance for the money or all out with an X1300/X1550 ( same thing just 2 diff names )
If you wanna keep spendage low with decent performance then grab an FX5500.
It doesn't? I thought it does.fx5500 is not an option. Shitty card and does not support SM2.0.
It's pretty low-costing though. I think I've seen them for FAR.FX 5500 is a rip-off. Just buy a FX 5200 and overclock it to FX 5500 speeds.
Due to the driver issues with the HD series and thier Pci/AGP counterparts I'd say steer clear of any HD card that isn't Pci-E.
And for a low cost solution the FX5500 is the best bet, if you get an FX5200 Pci card be prepared for the fact that the Pci versions of those cards don't OC for shit, I speak from experience on that one.
I can say that the X1300 Pci cards Oc like mad on the core but generally don't budge much on the ram. I bought a Visiontek one for a friend a lil over a year ago and it Oc'd to 670 on the core but the mem didn't budge even 2mhz :/
Don't let people bully you into buying a card you don't need just because it's the newest of the new. People that rant and rave about the latest just because it;s the latest generally don't know squat about what they're spouting.
Oh, lets not forget that any card faster than the 6200 Pci card is going to be severly limited by the Pci busBet the HD2400 guys didn't know that. The only thing you'll get from any card newer/faster than the 6200 are extra features and maybe the ability to crank up AA/AF a little more but your FPS will be limited not by the card but by the piss poor bandwidth of the Pci bus which lays somewhere between AGP 1x and 2x bandwidth equivelancy.
TBH I'd prob not buy anything faster than a 6200, just make sure whatever card you choose has 128-bit memory if you want to do any kind of gaming. Also stay away from 512mb HD2400's, X1300/X1550's and 6200's ( if they exist ) as those GPU's can't push any resolution that would use that much memory, also avoid 256mb FX5200's and FX5500's if possible as those card aren't good for resolutions that can use more than 128mb.
