Fastest GPU a Pentium G630 will support
Slo Gun
I recently upgraded the HTPC with a Pentium G630.
Its accompanied by an ageing 9800GT, which is ok for playing a few light games at 720p.
I am considering getting a faster GPU, and was wondering what peoples thoughts were on the fastest GPU this chip will support before it becomes a bottleneck?
I'm interested in Nvidia cards, but if anybody has any experience running ATI with this processor please share.
That processor is basically an i3 lacking the HT and clock speed. In games they will probably perform very similarly. Since most people compare i3s to Bulldozers and Phenom IIs, it would be reasonable to assume it would adequately push all but the highest-end GPUs.
for 720? or is that just the res you play at with the 9800gt?
The display is 1080p, the 9800gt can't run most games at a stable framerate above 720p so that is the res I have been using.
Long term I will eventually transfer my GTX 580 from my main rig into the HTPC;(I expect this to be bottlenecked but the low end cpus may have come on enough by then for me to buy a suitable replacement)
In the interim I would like to get something more powerful than the 9800GT I was considering something like a second hand GTX470 but have concerns that this would be bottlenecked and would rather spend the cash on something a bit cheaper and less powerful that perhaps would not be bottlenecked.
So really i'm looking for peoples opinions/experiences on what the fastest card is that I could pair with this CPU before it hits a bottleneck and returns diminish.
580 fr an HTPC?
and please do not get a loud, hot, power hungry 470. just get a new 7850 2g for around 200 bucks.
580 fr an HTPC?
Call it what you will, it's a PC that sits under the TV next to my amp and looks more like a piece of AV equipment than a PC :D
So in your opinion a 7850 would not be bottlenecked? If so is that from experience?
well your cpu will even limit some games in general and overall will certainly limit the 7850 a little bit but nothing terrible. a 7770 for just over 100 bucks would not be held back but a 7850 would be much faster in gpu demanding games.
I think something like the 7850 would be OK as well, you may not get max performance out of it but your experience should be fine. I've seen people saying the dual-cores aren't great for BF3 since it is pretty CPU heavy.
