5000+ black edition or 5600+ black edition are the 2 fastest ones that I am aware of they are also able to clock up to match the 6400+ without issue and nearly as fast overall.
The 6000+ might work, but it also will probably fry the socket with heavy load or extended use.
SOME AM2+ cpu will work fine in AM2 boards example http://www.overclockersclub.com/reviews/athlon7750/16.htm if you can still find them. I would send an email to biostar or check the BIOS version history to see what processors are supported, it might be brutal hard to track down a "true" AM2 cpu, whereas there are still quite a few AM2+ cpu kicking around.
A quote from an article
Socket AM2+ with DDR2 for the 65 nm Phenom and Athlon 7000 Series
Socket AM3 with either DDR2 or DDR3 for the 45 nm Phenom II Series. Note while all K10 Phenom Processors are backwards compatible with Socket AM2+ and Socket AM2, some 45 nm Phenom II Processors are only available for Socket AM2+.
Seems as long as its an 89w or less AM2 processor, you should be fine. There is apparently no support for AM2+ CPUs in the bios.
