Fastest 7200rpm
R
ring.of.steel
Guest
hi, what is the fastest 7200 rpm drive that i can get. preferably under 320gb. will be getting 2 of them for raid 0.
cheers
Probably one of the 7200.11 Seagate drives, but newegg doesn't have them yet =(
I have a pair of the original 36GB raptors in a raid 0 array. I wonder if this drive is faster than those.
edit: on hdtach right now I get 99.2 mb/s average read and 168.5 mb/s burst
depends, but probably.
Raptors typically stomp at random access speed.
But the latest 7200rpm drives are getting fast, and beating them in transfer rate.
Access time is a tricky thing. Sure the quoted number on the WD360GD is lower than what most recent gen drives can offer. However it does not take data set size into account. Access time across a 30GiB data set requires a lot more distance to be covered by the WD360GD than a current generation 1TB drive.
