Faster gaming hard drive?
Obiwanshinobi900
Personally I would go for the Samsung since it's a bit more storage space for not much more money. I doubt you'll notice a performance difference between the two. Being a Samsung probably means it's a little quieter too.
Go with the one that you feel is the best deal. I usually go Seagate for the warranty, but I see the Samsung is larger. The Samsung seems to be hit or miss on the failures. If it is not DOA, you're probably good. Most likely not a lot of speed difference in loading games, and they will not have an effect on your framerate. Of course there is the Raptor, and RAID 0. Both are faster, but cost more, and RAID is not for everyone.
Between the two, I would go with the Samsung as it is larger and from what I've read, are darn good drives.
the new wd ones could be what you want.
huh? :confused: Care to explain exactly which model you are referring to? If you are referring to the GP drives, I would avoid using that as a main drive as they are meant for storage, not performance.
