Black Label
- Sep 8, 2004
i have a 9600xt
Edit: o yeah v sync on or off
Bacon is evilphaelinx said:i like bacon.
Glow said:why would I want to keep it on with my 9600XT?
So why would I want it on with a 9600XT then?wallijonn said:Fast writes disabled will make the video card not use the video card onboard memory but will instead use the memory from System RAM. So make sure that you have your agp size set correctly in the BIOS. Your agp aperture size should be 1/4 to 1/2 your system RAM size.
let me know what you see, I forget what I have it set at?Black Label said:so i can disable fast write and set apg aperture size to 256 of my total 1024 of ram? will i see any performance boost by doing this?
lol... How on Earth did you comes to this conclusion? This thread is n00bie central..wallijonn said:Fast writes disabled will make the video card not use the video card onboard memory but will instead use the memory from System RAM. So make sure that you have your agp size set correctly in the BIOS. Your agp aperture size should be 1/4 to 1/2 your system RAM size.
Silverghost said:lol... How on Earth did you comes to this conclusion? This thread is n00bie central..
From Adrian Rojak's site www.rojakpot.com (who by the way is THE authority on bios settings):
This BIOS feature controls the chipset's AGP Fast Write capability. Fast Write is a feature which accelerates memory write transactions from the chipset to the AGP device.
Normally, any data meant for the AGP device must be written to the main memory for the AGP device to read. Fast Write allows the AGP device to bypass the main memory and directly access the data. To do so, the AGP device will act as a PCI device whenever the chipset attempts to write to it. This allows the data to be directly written to the AGP device (like other PCI devices), instead of being written to the main memory first.
As you can see, bypassing the main memory saves time and improves the AGP read performance. However, AGP writes (to the chipset) will not benefit from Fast Writes as it will follow normal AGP protocol and write to main memory.
In addition, while PCI signals are used for Fast Write transactions, the behaviour of those PCI signals has been modified and do not follow PCI specifications. Therefore, this feature may cause problems with some PCI cards.
Therefore, it is recommended that you enable AGP Fast Write for better AGP read performance but disable it if any of your PCI cards start acting funny.
Please note that for AGP Fast Write to work, both motherboard chipset and graphics card must support the Fast Write protocol and the data transfer rate must be at AGP2X or faster.
AGP Aperature size has nothing to do with Fast Writes. Read this.Black Label said:so........if i enable it, what should my agp aperture size be set as?
