Folks, I could use some advice. I am currently in the process of deciding what hardware to buy for a project I am working on. I have a master computer that currently contains roughly 600 GB of source data (and growing), and then I have currenly 8 client machines (soon to be 18) that access the master, grab a chunk of data, process it, and return the result to the master machine.
The data blocks that are read and written are small, it seems to me less than 32k at a time, I could get the actual number from the developers I suppose.
The machines are behind a gigabit switch, and do make use of gigabit network speeds.
My question is, what would be a good setup to facilitate fast read and write access?
I'm considering to just create two four disk RAID0 setups in an 8 disk rackmount enclosure using 200GB or 250GB disks. Thus the source data could be read from one striped array and written to another striped array.
Anyone strongly opposed to that based of efficiency or performance?
Edit: Another question is (and I am not sure about which enclosure I am going to buy), is a 2 channel raid controller sufficient for 2 four disk arrays, or would I be considerably better off to have a controller that has as many channels as I a going to use drives?
Another Edit: Ultimately I will have to think of something to back everything up. Tapes are imho out of the question because they just don't hold enough data per cartridge. Any suggestions for a JBOD that doesn't cost an arm and a leg (already forking that out for the rackmount enclosure)?
