Fast clock
Format _C:
Is this an issue with Nforce 2? I have this problem with the clock on my Nforce2 boards being about 5 mins fast. both my computers. My main box I don't rally care. but my HTPC must be correct as it records TV for me. How can I fix this? I know XP dpes it but only one every 3 days.
Why don't you just change the time? Does it revert when you try to change it? Does it actually tick fast? (dont see how that could happen)
5 minutes fast, I don't get what you mean by that. If you set the clock properly in the BIOS and then save/exit and boot into Windows, disable the Windows Time Sync and then just leave it. It shouldn't be different than what you set in the BIOS.
