Farcry problem
roger2
hi guys ive got a little prob wid farcry, wen i go to instal it after the autorun it just shows a ms dos window that quickly dissapears after a second and nothing happens after that, the first time i installed it it installed fine, y is it showing my dat msdos window and just not installing :confused: help me pls as i would luv to play good old farcry once again, i think i tried everything to get it to work
Try opening the setup.exe on the disc manually. It might also work in a different drive, if you've got more than one. Other than that, copying installation files to the HD often fixes problems like this.
