Farcry mouse lag
ec_hern
The mouse just doesnt "feel" right when I play, its lags a little, its annoying enough to where I don't want to play the game anymore. Anyone else have this problem or know a fix for it?
demo, full?
EDIT: did you try messing with mouse sensitivity, i had to up mine quite a bit
full, but I noticed it in the demo also.
yea i messed with the sensitivity, acceleration, all that stuff. Its like when i first start to move the mouse, the movement on screen will be slightly slower initially than what I'm actually doing. Makes it so im shooting all ove the place just not where I want to.
Using a logitech MX700. Never had any problems like this before.
Yup, I have it too, that's what caused me to stop playing it.
BTW, was the demo.
and i have a Logitech MX500 w/ latest drivers.
Man if that is how it is supposed to be I can't see why anyone is playing it. The game looks so incredible but playing it just drives me crazy.
hmm....i know exactly what you are talking about ....I found it annoying in the demo. I guess i just got used to it.
Here's something i'd recommend. Just for experimental purposes, turn the res + eye candy all the way down, i bet you'll find that the mouse is all of a sudden normal.
I think we all need a bit of next gen hardware to get some better gameplay out of these next-gen games.
I've noticed the exact same thing - with all settings down, it plays very similar to any other fps. It's not the games fault, it's the current hardware.
I have the retail..I have this also, and its really annoying...
I hope they fix it with a patch or something
Weird, mine is just fine.
Here's what I'm running, with the Full retail version
2100+
9600pro
512mb
SB Audigy2 ZS
Intellimouse Explorer 3.0, wired
@1024 32bit, noAA, or AF
I had to turn up the sensitivity a bit, but the mouse is fine, no lag.
I dont enable all the AA/F eye candy, it doesnt really matter to me that much, since at resolutions 1024+, you dont notice it all that much anyway, unless you have a $500 vid card.
My fps is pretty smooth, i'd guess in the area of 40-60.
