Great_Melinko
- Mar 19, 2004
It still works but any small text and details are all blocked and fuzzy. Does anyone know if Interage has RMA?
V0ltage said:it most likely overheated it.
get a new cooler to see if that helps, if not, RMA.
i hope so too, this one sucked at ocing (it wasnt oc'd at the time it died) mebbe ill get a better one.CVNet1 said:I think it would be funny for Interage to shoot back an email saying Warrantee void due to running high performance game (AKA Farcry). But seriously, I hope you get it working or get an RMA on it.
heheheheSilverghost said:Get the eggs ready![]()
i shall tommorrowSyphon Filter said:can you take a screen shot of what you are seeing?
Great_Melinko said:![]()
This is pretty much what it does
Merlin45 said:I think that the better choice of title would have been, "Farcry put my 5200 out of its misery"
Only way is it keeping the card under load and the card over heating.Neural Interface said:hahaha thats what I would have said lol![]()
Seriouslyt though I dont think even almighty far cry could "damage" a graphics card, on the bright side you can get something better than the curse which is the Fx5200![]()
umm i play farcry with everything on medium and its more than playable.Sir-Fragalot said:Well first off a 5200 isn't really fast enough to play Farcry well. Secondly there are alot of driver issues with v1.0 of Farcry and certain Nvida 60 series drivers.
Patch Farcry to v1.1 and try some different Nvidia drivers. If your card still works fine in Windows and other games it's not dead. If it doesn't work fine in Windows and other games it's likely screwed.
