\ca_DrawBones 1: display bones used by skeletal animation engine
\cl_display_hud 0: hides the HUD, play in full screen
\hud_panoramic 1: use with cl_display_hud 0, play in letterbox mode for a movie-like experience
\e_terrain_lod_ratio: set to 1 or less to display more detail in the terrain far ahead
\g_maxfps 15: (ATI cards only) simulate the game running on GeForce FX hardware
\MemInfo 1: display interesting information about game modules and memory consumption
\r_DisplayInfo 1: display performance statistics such as fps, number of polygons in scene, etc
\r_Stats 1: display info on current shaders and textures
\r_RenderMode 1: use "soft light" renderer for a dreamy effect
\r_RenderMode 2: use "cold colors" renderer for a realistic effect
\r_RenderMode 1: use "cel shaded" renderer for a cartoony, XIII-like effect
\r_RenderMode 1: use "ultra contrast" renderer if you want to ruin your eyes because you can't see anything
\e_water_ocean_sun_reflection 1: enable cool effect of sun reflecting in water
\r_WaterReflections 1: already enabled by default, consider disabling it to boost fps
\r_WaterRefractions 1: disabled by default, enable for refraction effect in water
\save_game AnySaveGame: saves the current game into the file AnySaveGame
\load_game AnySaveGame: obviously, loads save game AnySaveGame from disk
\start_frame_display: I'm not even gonna try to explain what's going on there, lots of cool renderer stats
\start_frame_profiling: remove stats shown with start_frame_display
\w_recoil_max_degree 0: for you ladies out there, disables the recoil of all the guns
\w_accuracy_decay_speed 0: another one for the mouse-handicapped, gun accuracy remains steady while firing
I found the middle one really funny turn your ATI card into a Geforce FX
FPS=15 lmfao
FPS=15 lmfao
