Just tried it.. still doesn't work.todlerix said:turn off aa (make sure u have it turned off in farcry if u have it app controlled or nvidia display options if u have it on in the nvidia control center)
~ tilde for console
\r_hdrrendering 7
Yep yep yep. I copy pasted exactly from several threads. I know I'm doing it right.jdunner3 said:are you typing it into the console correct? try changing the name of the farcry.exe file in your install folder and make sure your shortcuts are aiming to the correct file (newly named file)
IceWind said:You have to put -DEVMODE in the games shortcut for it to work.
Apple740 said:Don't know if it's required but sure you have DirectX 9.0C installed?
