Far Cry help
wopsang
I tried searching around but so far no luck.
I bit on the Far Cry 2 deal on Steam and DL'd Far Cry 1 but it won't launch. I'm running it on the specs in my sig. I tried installing the 64 bit patch but it wouldn't install. Anyone get it running with Vista 64?
Thanks in advance!
I bought it on Steam and was able to launch it the first time with no problems, and I am running Vista 64. Try deleting it and re-downloading it...other than that, not sure...I would suggest checking out the Steam forums and see if they can help at all....
