Originally posted by H0liday
Just loaded UT2004 Demo. Plays great at 1280x800. Can't figure out how to run the benchmark all the directories are empty and they've diabled searching on all the atari forums. Googled it with no luck. Any ideas??
Originally posted by netdale
Can I get a port replicator for my eMachine?
Would this work?
http://www.topmicrousa.com/3030003.html
I know many manufacurs use the Asus one...
Dale
Anyone have software or a driver that will allow us to configure those buttons (search, etc)???
That would be sweet if we could personalize them!
Dale
Ok, I have power management on (obviously) in my clean install of Windows XP Pro. Yet when I leave the machine go and turn the monitor/lcd off I have to use the function key (FN+F4) to get it to come back on. Suggestions? Is this normal? Do you guys with XP Home have this issue?
Thanks Dale
Originally posted by Sacrificial
I have already messed with the SODIMMs in my M6805.
Two sticks of Kingmax 512Mb DDR400 (2.5/3/3/8 @ 200Mhz) will not work. The BIOS info will boot and you can get into BIOS setup, but Windows will not boot. Supposing eMachines posts a BIOS revision that allows us to work with latency timings (fat chance), then there might be a chance of getting this setup to work.
Two sticks of Kingmax 512Mb DDR333 (2.5/3/3/7 @ 166mhz) runs great, noticeably better than the 768Mb that I ran for a week before I opting for the second SODIMM. The jump from 768Mb to 1Gb made the more noticeable reduction in page file access.
Accessing the internal SODIMM is not recommended for anyone but the most die-hard upgrader. It requires tracking of some 30-ish screws of varying dimensions and careful manipulation of wire-tethered components around the fragile LCD, which does have to be separated from the body of the laptop in the course of opening it up. Not for the faint of heart even if you had the disassembly sequence available to you.
Being that this is the case, I think finding a cheap single stick of 1Gb DDR333 SODIMM would be the hot setup for the majority.
While I was in there I took the opportunity to lap the CPU heatsink and replace the OEM foil-type thermal interface with Arctic Silver Ceramique, which presumably achieved an increase in thermal performance by reducing the frequency at which the fans came on, but producing a hotter exhaust when it did. FYI, the thermal solution is a twin centrifugal blower, triple heatpipes
(two to the left radiator, one to the right) with a copper CPU face.
Originally posted by lopoetve
You opened it up wrong.
Read the other opening thread, there is an easier way to get to that other SODIMM.
Originally posted by blindbug
Mine is model number: IC25N060ATMR04-0
Im going to open it up tonight to see if this is what it says on the drive itself.
Originally posted by emXry
i am looking into one of these eA64 machines myself.
can anyone tell me how loud the machine is with...
1) idle
2) can you hear the "whining spin" of the hard drive? what model do you have?
3) can you hear the "crunching" of the hard drive during read/write? what model do you have?
4) how loud the fan is?
5) any other noise issues i am not asking?
thanks!!!!!![]()
1) Nearly silent. As in inaudible.
2) No, and I have the Hitachi Travelstar 5600rpm model.
3) It's more of a series of muted clicks.
4) When the fan is on, you can still whisper over it.
5) Nope. The laptop is quieter than my old Sony PCG-M505F, which had no fan but plenty of hard drive whirr.
Why not go to a store and ask to hear for yourself? I'm sure it's a reasonable request for them to oblige.
thanks for the quick reply. i wish i could go to a store, but its a ways away...
also, where is the best deal for this laptop? any rebates besides emachines currently?? how much is an additional 3 year warranty over the one year??
Originally posted by scatpack
Dont waste your time! I bet $20 youll find thats the hard drive you have inside.
I just got my M6805 today after on an order at the end of the week from best buy... I don't have any of the 4 hard drives already listed![]()
After some searching I found it to be a 4200 RPM, 2MB Cache Hitachi Travelstar![]()
Link here...
Originally posted by dabey?
no that url and many more like it have incorrect specs. the official link is here http://www.hgst.com/hdd/support/80gn/80gn.htm there you will find the real specs of your HD its is the same as mine 4200rpm, 8mb buffer.
Best deal: Best Buy.
3 year through eMachines is $180.
Stabby, why won't you bother buying through best buy?
