Fans?
Zake202
What would be a good fan to buy that is under $10 each?
I'm looking to add 1-2 more into the CM690.
Yate Loons from Petra's Tech Shop are quiet, good quality, and affordable at about 6 dollars each.
I was thinking 2 Scythe fans for exhaust and intake.
Any suggestions for which ones?
I was thinking the 110CFM ones, but the dBA is 37, which seems high and people say is loud. Also, spinning at 1900 RPM's it probably wont last as long as a slower one.
the other 2 options are 66CFM@24dba 1200RPM, or the 88CFM@33dba 1600RPM.
Any suggestions over those 3 fans?
I also ordered 2 more of the LED CM ones, not because of the LED, they were $10 together and rated something like 40CFM@20dba. *Shrugs*
