My computer case sits below a desk kind of in the corner but not butted up against a wall. I have a few questions about which way the air should flow.
Heres the current fan direction...
PSU Fan - downwards into case (cant change that)
Side 92mm Fan - Inwards pretty much blowing directly on top of the CPU fan
CPU 92mm Fan - Blowing towards the CPU from the top of the heatsink (TR XP-90C)
Front 120mm Fan - Intake
Rear 120mm Fan - Exhaust
What can I do to make the airflow better in my Thermatake Tsunami case or is it optimal? The cables are managed with very little in the way and my two hard drives are spaced apart to allow the 120mm fan blow between them.
What would happen if I made the front an exhaust and the rear an intake (hahaha...i said rear intake)?
Thanks!
Thanks!
