Okay, I've already done a search on this topic, and as instructed by previous posts, I tested my mobo/PSU/cpu outside of my case. Since this setup still doesn't produce a POST beep, I've concluded that one of those 3 parts - the mobo, PSU, or CPU, must be the culprit. So far so good, right?
There's one more piece of information, and I'd like to know if it makes a difference. The moment my computer stopped POSTing occurred immediately after a crash. The computer's been running fine for months (with occasional cpu overheating or memory problems, which I've fixed) then all of a sudden it crashes without a blue screen and fails to POST afterwards. Does this additional information give any indication as to whether the problem is due to either the PSU, mobo, or CPU?
My current plan is to buy both a PSU and a mobo, and if replacing both doesn't solve the issue, then it must be the CPU at fault. Does this sound like a good plan? If you guys can narrow the culprit down to 1 part, I won't have to waste money on extra parts to replace an item that was already working properly.
Thanks in advance for any suggestions!
