Fans that look good?
Comixbooks
I had some Red fans in my Enforcer case now I switched everything to Green.
Now my case looks ugly rather then nice.... So I picked up some Yellow Kingwin fans but I'm reading they are not very bright the leds.... Was looking to mix up the Green and offset the case with 1-2 Yellow fans. I should of went with purple! Or blue Red is OK but purple is the shit....
I like purple but I could of bought a new case for all the fans I bought.
You can always disassemble the fans and paint the blades your desired colour. Additionally you can just chop the wires to the LEDs so they dont shine (if brightness is a concern), which is what I do on all stock fans that ive got that came with cases.
Or you can just buy some good fand and LED strips to get the lighting you prefer. Corsair makes some great case fans in the AF series. LED strips arent expensive either and put off considerably more light then most case fans
