TownRanger
- Jul 9, 2006
Hi, I'm a n00b in case modding. I don't have a dremel or any modder toy. I noticed a little something about how the dBAs of fans are measured.
Getting to it, the other day I got a 120mm rated 19dBA. I installed it at the back of my case as an exhaust fan with some silicon sound dampening screws. I also connected it to the fanbus to decrease its rev to reduce noise. I presumed that will work like heaven for me. And when I switch it to the maximum, there will be some, but not annoying, noticeable sounds from the fan.
Yesterday I got a 80mm one rated 27dBA. My first impression is, it's "loud and clear!" But a strange thing happened. I installed it on the side panel and also I made its 4pin connector to my fanbus. I switched it to max but it does not sound as much as the 19dBA one does!
I then have a browse through the paperbox and the websites of the fans. The criteria of measuring the dBAs are actually a whole lot different. The manufacturer of the 120mm one specifies that the noise is measure from a distance of 1m away from it; while the 80mm one does not tell how they measure its noise.
I start to think, if it is up to individual manufacturers to decide HOW and HOW FAR AWAY they are going to measure their products' dBA, that will create an unfair environment. It's also very hard for us to believe the data written on the package or in the website. There's always no fair comparison if fan noises are to be measured in anyway any manufacturer likes.
So if we want less noise by choosing a fan with a less rated dBA, then there's no guarantee it'd be up to our expectation.
