kipling100
- May 24, 2007
Hi, so I added a MCR2200 to my case with 2 120mm yate loons attached. However, I get this really loud vibration when the radiator is attached to the fans (sounds like a faint vacuum cleaner, if that makes any sense). When I just attach the fans to the grill on the case, it is fine, so I'm pretty sure the fans + the radiator is the source of this annoying noise.
Does anyone else have this problem? Would adding one of those vantec dampener things help? I'm concerned about adding another layer to the fans, b/c the 1" screws I have just reach the radiator (through the radgrill, case, and fans) just barely. Speaking of which, do you think longer screws would reduce the vibration much?
Thanks!
Thanks!
