Fans - good job?
stain.
I just picked up 2 of those 13cm fans from Thermaltake that fit 12cm fan spots.
Does anyone know if they are good?
I also picked up 3 yate loons.. the Orange blade, high speed fans. I'm not a quite computer person.. can you tell?
Maybe it is good.
What is CFM and dBA on it?
I have some Red and Black Thermaltake fans. I have not installed them as I am case modding still. I hope they are sufficient :eek:
i have a thermaltake Armor fulltower, it has a rear 120mm fan and front 120mm fan a top 80mm fan and another rear 80mm fan
all sweet
Just a heads up, the 13cm fans from thermaltake that are set up to fit in 12cm fan holes, yeah.. they don't fit inside the p180.. I found tha tout the hard way.. Case modding , here I come!
14dBa from 10 feet away maybe. TT's rating's are a joke, and IMHO there needs to be a set standard as to how manufacturers rate such things. For example low speed Yate's are rated 47cfm, at 28dBa.. So if that fan really does put out 54.4cfm, I'd have to figure it's dBa rating is just north of 30dBa really.
Oh, and the small fans on the Armor are 90/92mm's not 80mm. And the top spot is pretty useless IMHO w/ how restrictive it is (took mine out along w/ the wings the moment I got it), but I digress - seems the OP has an Antec case anyway.
I'm on the moove to modify the Antec case again... Here I go to get some riveting stuffs.. or screws and bolts for the ghetto look.
